08-07-2012 04:33 AM
I just came accross something strange when I use the context menu option "Make typedef" on a cluster constant containing a Boolean with visble label.
First a VI snippet with the before, it can be used to replay the event "Make typedef" through the context menu.
Then the result:
The size of the resulting Boolean image depends on the length of the label, the longer the label to larger the image (stays square).
Solved! Go to Solution.
08-14-2012 03:58 AM
Hello André,
Thanks for posting your question.
I tried to reproduce the behaviour. I was not able to reproduce.
My version of Labview is Labview 2011SP1.
What is your Labview version?
Eventual, its solved in a newer version of Labview.
Best Regards,
Corné Westeneng
Application Eningeer
NI-Netherlands
08-14-2012 05:41 AM
I can confirm the OP's results. I am using LabVIEW 2012 with the 0f1 patch. As mentioned, when you turn the label off, the issue disappears.
08-14-2012 06:35 AM
Well, I can reproduce the behaviour. I saw that we have a CAR (Corrective Action Request) allready, so our R&D department knows about it.
At the moment we do not have a workaround or solution so far.
Corné Westeneng
Applications Engineer
NI-Netherlands
08-14-2012 07:54 AM
The issue also disappears when you select "Apply Changes" in the control editor. (work-around #2, number #1 being use "Make Typedef" with the Boolean label invisible.)
08-14-2012 08:04 AM
Allright then we have a workaround ![]()
12-14-2012 07:08 AM
LOL
