Breaking Up An Arc
My little CNC machine gags when I try to cut an arc > 180 degrees.  I want to cut a CW arc that's nearly a full circle; so I have to break it up into smaller arcs.  I use an increment of 120 degrees.
The attached VI works fine, but I wonder if there's a cleaner way.
(512 Views)
t are typical default values? With the current settings, we only get four points, forming a triangle, not an arc. I assume the machine has an arc command and these are the starting points?
I have the feeling that things could be simplified, but I am heading for the airport. Maybe I have WIFI in the terminal.... 😄
(495 Views)
Yes.
Yes (except the last one is the end point).
(469 Views)
In the original, I forgot to add back the offset for the center (I didn't notice at first because I was using (0,0) as the center).  Here is the fixed version.
(465 Views)
Here is my latest version (can't attach .vi because the file attacher is broken again).Break Arc Into Segments.vim Snippet.png
(457 Views)
Granted, I don't know what commands your CNC wants, but I was really wondering why you did not shift based on the center.
Here's a quick idea, but please verify. There are two possible paths going from start to end (CCW, CW). Can we assume that is defined somewhere?
(377 Views)
