Breaking up a CAN Frame
I Have a Frame that I am trying to brake up
The Frame contains an Array containing:  Time stamp, 64 bit pay load, CAN ID, Type and if extended.
I Need to extract just the 64 bit pay load but am not finding a good way to do it.
The 64 bit pay load contains 2 32 bit IEEE 745 floating point numbers.
I am using the example CAN FRAME INPUT STREAM.VI with data coming from a TI. Launch pad.
It is generating all the required data
I have tried some of the ARRAY icons ARRAY SUBSET etc without any luck.
Anyone got a good idea
(2,706 Views)
  1. Are you using a NI CAN interface and NI-CAN?
  2. Do you have the devices' "secrete decoder ring"  to decode the CAN frame?
Here's an example of a CAN bus "sniffer" I write for a Toshiba Lithium Battery pack. It should give you an idea of how to do it...
=== Engineer Ambiguously ===
(2,702 Views)
Thanks for the VI
The Bus is being handled by an NI-USB8502 which uses NI-XNET.
I found that I am having a little luck using the Delete From Array Icon then use the deleted output.
Next I need to split up the pay load into 2 32 bit binary sections.
(2,687 Views)
Hi John,
So the payload contains 8 bytes and you want to create 2 numbers from it.
Are those numbers integers, FXP or SGL entities? (SGL because of your other thread where you also forgot to provide useful information.)
You may use UnflattenFromString:
(You may also use a typedefined cluster instead of the SGL array constant…)
(2,642 Views)
