Bug with FPGA Memory Items
I have LabVIEW 2025 Q1 and in a project with multiple CRIOs, many of the memory items in my project for multiple targets have been deleted or are corrupted:
I have always been plagued with issues regarding the memory items, however, it seems that a recent update or change has really broken things.
Any ideas what happened or how to fix?
Many thanks
Message 1 of 10
(3,659 Views)
Seemingly related to this issue....https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000xBFtCAM&l=en-US
Any suggestions on how to overcome? Or even just to restore my memory items?
Message 2 of 10
(3,627 Views)
Can you attach the original .lvproj file (presumably saved in some previous version of LV before 2025Q1 where the items are not broken)? Basically fishing for how we can reproduce the corruption process and debug...
Message 3 of 10
(3,624 Views)
I'd rather not post the .lvproj, as it is a large project and I'd prefer not to give away its structure.
All memory items which had a fixed-point value type have been affected; memory items with non-FXP data types are fine (except that many registers disappeared).
Is there a way to programmatically generate these memory items so that I can avoid the buggy LabVIEW project interface?
Message 4 of 10
(3,568 Views)
Accepted by topic author Gryffin
I never create BRAM in the project. I always use the tools to instantiate directly on the block diagram. The following is from a Flex-RIO target, but I would assume the same is available for your target..
You should have the ability to drop a "create BRAM" on the block diagram where you can open the configuration dialog to set up everything you need.
The best advantage is portability, the source code is self-contained. If you need a second copy, just copy the VI on the BD and you're already ready to go. In VHDL, the BRAMs get named based on their full hierarchical path, so they will still be uniquely named internally.
As you can see above, the same ability should exist for Registers, handshakes, FIFOs and Block RAM. The only thing I would like which is NOT supported is DMA FIFOs (To or from target). They must be project items.
Message 5 of 10
(3,526 Views)
Hello Intaris,
Indeed, that is what I've resorted to (the many wires of the Registers, BRAMs, and FIFOs make me sad...).
It seems that the only choice for the Host-To-Target and Target-To-Host FIFOs which have fixed-point type and were corrupted is to delete and remake them whenever they get corrupted.
Quite annoying!
Message 6 of 10
(3,505 Views)
I've moved the code base to another PC after reimplementing all block memory in the VI itself, and low and behold, the FIFOs I had recreated with FXP type are corrupted again and I need to remake all of them.
How do I stop this? I am having to fix my FPGA memory items nearly every time I open my project, and I've never encountered this bug before...
Message 7 of 10
(3,463 Views)
Moving between machines is an interesting detail. I tried a simple fxp memory and fifo item in a project and moved it between machines and it didn't break. So there is still something else unique about your setup. It seems like you can easily reproduce so maybe you could share a simple throw away project that reproduces?
Message 8 of 10
(3,458 Views)
I believe I have found the issue and it resides with Git.
I use Git to backup/version control my LabVIEW code and I recently moved to a new PC where I seemingly didn't have my environment configured exactly the same.
Specifically, I think the issue lies with the "Auto CRLF" behavior of Git. I had mine set to "false" (locally, globally, everywhere).
I thought that this would preserve the file exactly as Windows handles it, however, it seemingly has a negative effect (but it is not exactly clear what is happening).
The solution I finally came upon was to include a ".gitattributes" in my LabVIEW repository with a single line:
* binary
This treats all files in the repository as "binary" (so no line-by-line changes) and seemingly has resolved my problem.
I hope this helps someone!
Message 9 of 10
(3,232 Views)
Had this same issue!
Thanks!
Message 10 of 10
(2,619 Views)
