CTRL+V works fine with "Key Down?" event in , but not when the VI is inserted into a SubPanel — any ideas?
Hi everyone,
I'm working on a VI where I use the "Key Down?" event to detect user input, specifically to validate a String Control. The idea is to analyze every key the user presses, and also inspect the full string after a CTRL+V paste operation.
Everything works as expected when the VI runs standalone (i.e., in the context). However, when I insert the same VI into a SubPanel, the paste operation doesn't seem to trigger the event — it's like the "Key Down?" event isn't firing at all.
Has anyone encountered this behavior before? Is there a workaround to make CTRL+V detection work inside a SubPanel?
Thanks in advance!
(269 Views)
Accepted by CarPA
From Using Events with Subpanel Controls
If you configure a VI to handle an event and then configure the VI you load into a subpanel control to handle the same event, the top-level VI containing the subpanel control handles the event.
Bob Schor shared some workaround in Key Down Events in sub-Panel?
https://tmesystems.net/
(246 Views)
Accepted by CarPA
It is also possible to capture keys pressed on keyboard without event. It works on sub panels and also in vi's that are not in front :
(195 Views)
