Call a SubVi in Labview
I have a Main VI running. Now by pushing a Button, I wouldl like to open another VI or a SubVi.
How do I do that?
(14,758 Views)
Click on Help/Find Examples then go to Programmatically Cpontrolling VIs. Click on Dynamically Loading and Calling VIs and look for the Dynamic Load Example.vi
LabVIEW 2012
(14,755 Views)
Yes I have been playing with that example. But it has too many functions in it. I have used Labview about 6 years
ago writing Device drivers. But moved to Labwindows CVI and Visual C. I just want a very simple VI call
from another VI. To just have a button in the Main VI. By pushing the Button, the SubVi will come on.
I tried doing that by using Call By reference but not successfull.
(14,740 Views)
Accepted by bobby_y
You may have a look at the attached VIs.
Nitzz
(Give Kudos to good Answers, Mark it as a Solution if your porblem is Solved;))
(14,728 Views)
why dont you use Event Case?
(14,726 Views)
With the help of SUB FRAME you can call any sub vi inside your main VI.. rachit kapoor www.rachitkapoor.leehoan.com
(14,724 Views)
Regards
Bobby
(14,687 Views)
