Call2 method not found (ActiveX VI Method)
I have the following problem. I have an executable which has ActiveX Server enabled.
the code below is of a Caller VI. the code was working properly before. When i have inserted a new Invoke Node on the block diagram, i dont see any methods.
i think the picture below says a lot.
Please help!!
thanks
RENN
LV2010Sp1 32bit
Kudos always welcome for helpful posts 🙂
(4,335 Views)
any idea???
(4,303 Views)
Error from me!! solved
(4,295 Views)
Hello RENN,
its always a good idea to post the solution to a problem, in case someone else stumbles upon the same problem
Best Regards!
Moritz M.
(4,282 Views)
Accepted by RENN
Hi Moritz M.
sure. i am happy to post the solution.
Normally the ActiveX server is registered automatically when the executable starts.
But since the old EXE and new EXE has the same name, at first i had to unregister the old activeX server, (See the link: http://support.microsoft.com/kb/297279) register the new one manually.
Its also well documented on NI support page below.
How Do I Register Type Libraries, ActiveX Controls, and ActiveX Servers?
http://digital.ni.com/public.nsf/allkb/4F811A9B23F1D46E862566F700615B7A
i got the broken diagram in the caller VI (as i posted before) because the activeX Server (in my case the new executable) was not registered.
thanks for replying
RENN
(4,251 Views)
Hi RENN
By trying access call2 method the front panel was called up
But I can't deliver Param Names and Param Values into Exe, how to assemble correct format.
Brs
(2,823 Views)
