03-01-2007 04:16 PM
03-01-2007
11:18 PM
- last edited on
02-03-2026
04:23 PM
by
Content Cleaner
Hi rkpat,
You might check-out this [broken link removed 2/3/26] thread on building WIN32 DLLs - expecially the bit re: "mangles names" under the paragraph titled "C Language Source File". My recollection is that 'extern "C"' directive in the header file for the DLL solved the name-mangling problem, but it's been a few years! ![]()
Cheers!
Message Edited by tbd on 03-01-2007 11:19 PM
03-02-2007
01:27 AM
- last edited on
10-13-2026
02:08 AM
by
Content Cleaner
tbd is right. You have to first disable name mangling as it creates all kind of troubles. Other issues might be that your Visual Studio 2003 or .Net edition links in dynamic runtime libraries that are not standard available on every Windows PC so that you need to redistribute the according runtime library installer together with your app for the DLL to be even loadable.
@tbd wrote:
Hi rkpat,
You might check-out this thread on building WIN32 DLLs - expecially the bit re: "mangles names" under the paragraph titled "C Language Source File". My recollection is that 'extern "C"' directive in the header file for the DLL solved the name-mangling problem, but it's been a few years!
Cheers!
