Calling .llb file from a main.vi
I am trying to call .llb file from main.vi. What is the method of doing it. Tried calling the .llb file through call by reference method. I am using Labview 2016 and Vision 2016
(1,981 Views)
A .llb contains plain vi's. Right-click on the BD, Select a VI..., navigate to the .llb file, open it, select a vi.
Unless you really need to call it by reference.
Paolo
(1,975 Views)
Accepted by priya9129
Calling the VI dynamically is exactly the same as any other VI. The .llb should be in the path: C:\myllb.llb\myvi.vi.
Like any other VI, calling it as a sub VI should be preferred over dynamic calling.
(1,954 Views)
