Can I deploy Mathscript subfunctions without revealing .m source code?
Hey DCanQAlias,
I am not sure of how you would be able to do this. There may be something in your .m files that you can configure.
Making those into a DLL and then using the call library function node as mentioned earlier might be closer to that behavior.
Joe S
Message 11 of 12
(602 Views)
Hello.
Sorry for not replying to your post earlier, at least to say thanks for the help. I had to start working on something else, and I expect to get back on this issue shortly. I will try the ideas suggested here, and expose what finally worked for me, if anything.
Thanks again!
Message 12 of 12
(587 Views)
