Can I filter noise, given a specific filter algorithm?
I have an array of waveform data captured at 120MHz. I want to apply a specific filter to it remove noise (weighted to perception of eye to noise). Can I implement this in LabVIEW? Any clues how please!
Filter circuit this looks like;
Response of filter looks like this;
Alan
(3,179 Views)
OK, so with a bit of reading and a bit of playing I have managed to;
  1. Perform FFT of my input signal
  2. For each element of the frequency domain signal;
    • Converted complex to polar
    • Applied filter to modify (attenuate) the 'r' part
    • Converted polar to complex
  3. Real inverse FFT
This seems to work fine, however, I notice that in the final stage if I do a Complex inverse FFT then the resulting signal is about half the amplitude of what I'm expecting. Why is that?
I have set up a test signal of 10000 samples of a 100MHz Sinewave, however I see this happen at all test frequencies and number of samples.
(3,146 Views)
A complex FFT is two sided- and real frequency component at frequency f0 appears as two peaks on your FFT- one at +f0 and one at -f0. Each component is half the amplitude of the sinusoid. This is probably what you are seeing.
Filtering is usually performed by creating a filter (IIR or FIR) to your required specifications. Your method is a bit unusual in that a given output sample can be affected by a sample that comes after it.
(3,142 Views)
Thanks ToeCutter, looking at IIR and FIR, I would need Forward and Reverse co-efficients if I used IIR, and FIR co-effiecients if I used FIR. I am at a loss when trying to understand how these parameters can be defined.
Can you/anyone give me direction in where I can find how to arrive at values for these for the equation given in the first post?
(3,133 Views)
