Can I manually set x-y grid size on the waveform graph?
I want to fix grid size at 1*1 cm no matter how wavefrom changes.
Is it possible to do it? Thx!
(2,976 Views)
First thing you can do is disable the "AutoUpdate" for the Y and X scale by right-clicking on it... see below.
To make it 1cm*1cm... hmmmmm... if you set it as you want and lock it, they shouldn't move.
Message Edité par TiTou le 06-26-2006 03:50 PM
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(2,964 Views)
The size should not be changing, however the scales may be changing if you're auto-scaling.  You also have programmatic access to the size of the plot area using a property node - run the attached VI which illustrates this (I attached in version 7.1).  If you're still having problems, please explain in detail the behavior you are trying to implement or avoid - perhaps you can attach a very simple example which shows it!
Best Regards,
JLS
Best,
JLS
Sixclear
(2,955 Views)
