Can I stop the auto movement of the slide
Can I stop the auto movement of the slide.
I have a pointer slide with 8 slides. If I click in between the slides, the active slide will move to that position, when I just missed the one I wanted to move with the mouse. How do I stop this and only respond to the slide the mose is pointing to.
(3,193 Views)
With an event structure (you have one in your VI already, right?), you can setup to grab the closest slider.  See the example.
(3,188 Views)
thnaks, I am not familure with events and I have Ver 8.2 labview, could you attach a screen shot?
(3,155 Views)
Even better, saved for LV8.2.
(3,139 Views)
