Can I use PFI 1 on 5133 as outside edge trigger
Any vi I can use for config the triggering. Thanks.
(3,386 Views)
If you mean sending trigger signal to another device, you could use niScope Export Signal.vi
(3,366 Views)
Can I do like this,
Channel 0: data input
Channel 1: another data input
PFI1: A sine wave input, using the wave cross 0 point to trigger data collection for CH0 and CH1.
(3,358 Views)
PFI only supports digital trigger. You need to build comparator circuit with opamp to change from sine wave to 0/5V signal.
(3,349 Views)
Is there any detail reference of digital trigger.
Is it triggerred by voltage level or rising edge? Does it has the same accuracy with analog trigger. Thanks.
(3,344 Views)
Accepted by alex.
(3,340 Views)
Hi KateB,
Thanks for your info about PFI in 5133. Is there any info about general description about Digital Trigger, thanks.
(3,334 Views)
