Can I use PFI 1 on 5133 as outside edge trigger
Any vi I can use for config the triggering. Thanks.
(3,384 Views)
If you mean sending trigger signal to another device, you could use niScope Export Signal.vi
(3,364 Views)
Can I do like this,
Channel 0: data input
Channel 1: another data input
PFI1: A sine wave input, using the wave cross 0 point to trigger data collection for CH0 and CH1.
(3,356 Views)
PFI only supports digital trigger. You need to build comparator circuit with opamp to change from sine wave to 0/5V signal.
(3,347 Views)
Is there any detail reference of digital trigger.
Is it triggerred by voltage level or rising edge? Does it has the same accuracy with analog trigger. Thanks.
(3,342 Views)
Accepted by topic author alex.
(3,338 Views)
Hi KateB,
Thanks for your info about PFI in 5133. Is there any info about general description about Digital Trigger, thanks.
(3,332 Views)
