Can LabVIEW DSC Run on XP Embedded
cross posted to LAVA
Hi
Does anyone knows if LabVIEW DSC works on XP embedded?
These two posts are interesting: WinCE post cRIO post
Regards
JG
Message Edited by jg code on 03-04-2009 07:16 PM
Certified LabVIEW Architect * LabVIEW Champion
Message 1 of 16
(7,337 Views)
As far as my little experience in working with LV DSC goes, I dont think so it will work.
- Partha ( CLD until Oct 2027 🙂 )
Message 2 of 16
(7,322 Views)
Absolutelly not.
DCS uses OPC, and OPC is build on COM and DCOM, both M$. No way this will
ever work on any embedded device. Perhaps you can get some OPC programs
working on XPEmbedded and maybe even on CE, but since LabVIEW Embedded
compiles to generic C, it won't support OPC.
Wiebe.
Message 3 of 16
(7,291 Views)
Accepted by jgcode
Hello jg-code,
XP Embedded is not a supported Operating System for running LabVIEW developement environment or the DSC Module.  This does not mean that it will not work, only that we do not guarantee that it will work.  One reason for this is that XP Embedded can be made into any variety of installations.  The following link may provide some useful information.
Running LabVIEW on Windows XP Embedded
     http://zone.ni.com/devzone/cda/tut/p/id/4011
Message 4 of 16
(7,281 Views)
Thanks everyone.
Message 5 of 16
(7,269 Views)
Charlie, let me revise that. I missed the XP Embedded in the title. I though
you wanted to do LV embedded programming.
XP Embedded is in fact a more complete XP installation, if you install every
feature of it. So it should run just fine. It is not supported, but it will
work. We have LV executables running on it without any problem. When you
install programs, the programs have no way to distinguish between XP and XP
Embedded. But when you reduce XP Embedded, which is probably something you
want to do, you have to be very careful not to delete any dependancies.
Wiebe.
Message 6 of 16
(7,250 Views)
Yes.  I've don this on a RW touch panel running XPe. Installed the DSC RTE (note that this has a license fee), LV RTE, and the LV exe.  All went smoothly.
Message 7 of 16
(6,874 Views)
I did it once to my 2512 touch panel.  The only thing that took a while was setting up the DCOM settings.  I don't have specific instructions, by I think I used a Kepware white paper for step-by-step.  Of course if your DCOM is already setup, then you should be ok.
Brian K.
Message 8 of 16
(6,861 Views)
If y'all haven't seen NI now offically supports DSC on XPe with LabVIEW 2009
http://zone.ni.com/devzone/cda/epd/p/id/5956
Cool
Message 9 of 16
(6,849 Views)
hello,
so I´ve read your post and now still have some hope to be able install DSC on a Touch Panel running Windows Embedded PosReady 2009.
The problem is the following: on the propietary touch panel there is only 700 MB of space left. What I did was to mount a SD Card on a hard drive (D:\). Now I would have enough space (32GB) but the DSC installer doesnt let me choose the installation folder.Is there a way to change the default installation folder???
Please help me to find a workaround to this problem
montanaro
Message 10 of 16
(5,933 Views)
