Can a 6221 card be used to output a frequency of 50hz-7Khz with an amplitude of .1 Vrms to 10 Vrms?
Can a 6221 card be used to output a frequency spectrum of 50hz-7Khz with an amplitude that can vary from .1 Vrms to 10 Vrms?
VR
Patrick St. Germain
(2,479 Views)
You can review the specs yourself but with a max update rate of 833 Ks/sec and 16-bit resolution over a +/- 10 volt range, it should be easily doable.
(2,465 Views)
