Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Can a 6221 card be used to output a frequency of 50hz-7Khz with an amplitude of .1 Vrms to 10 Vrms?
thesaint
Member
01-09-2006
12:44 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Can a 6221 card be used to output a frequency spectrum of 50hz-7Khz with an amplitude that can vary from .1 Vrms to 10 Vrms?
VR
Patrick St. Germain
0
Kudos
Message
1
of 2
(2,478 Views)
Reply
Re: Can a 6221 card be used to output a frequency of 50hz-7Khz with an amplitude of .1 Vrms to 10 Vrms?
Dennis_Knutson
Knight of NI
01-09-2006
02:57 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
You can review the
specs
yourself but with a max update rate of 833 Ks/sec and 16-bit resolution over a +/- 10 volt range, it should be easily doable.
0
Kudos
Message
2
of 2
(2,464 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
