Can anyone help me with a HP4145B status byte?
I am running a VI that takes a measurement, and polls the HP4145 status byte to see when the measurement has finished before the VI continues. The VI has been working fine for the last month, but now I am getting a (-1) when I do a GPIB serial poll of the device. I am also getting Error 15, which means that the status byte queue is overflowing. This causes the VI to continue before the measurement has completed.
(2,772 Views)
You haven't included the HP4145 VIs in your attachment but even without them, I noticed that you have a case statement surrounding the GPIB Serial Poll and a False constant wired to the case selector. In your example, the GPIB Serial Poll is never being executed.
p.s. To make your code more readable, I would suggest getting rid of all of the sequence structures and just use the error in/error out clusters to enforce dataflow.
(2,772 Views)
Yes, I sent you the wrong version of the file. The case statement was put in later so as to "comment out" the serial poll and replace the frame with a "Wait" function. I apologize. But even without the case statement, it still doesn't work. I don't think this is a coding problem. And the HP4145 VIs are available from NI's website.
(2,772 Views)
