Can i use Labview for my Samsung S3C2410 board?
Hey Guys,
I have a dev board based on the Samsung S3C2410 processor
I bought it from developmentboard.net.  See the specifications HERE .
My question is:
I want to use LabView on this board, Can I?
Any helpful information will be appreciated, thanks in advance~
(3,518 Views)
Accepted by leon20008
Hi Leon,
I hope you are doing fine. You can use the NI LabVIEW Microprocessor SDK (Software Development Kit) along with a third-party toolchain and an embedded OS to target any 32-bit platform of your choice. Samsung S3C2410 is using ARM based 32-bit RISC Microcontroller , therefore you should be able to use LabVIEW. Please click here to find out more. I hope this helps.
Fawad Nisar
Applications Engineer
National Instruments UK & Ireland
(3,498 Views)
Thank you Nisar, your answer really helps. Thanks a lot
(3,490 Views)
Hi Leon,
I am glad it helped.
Fawad Nisar
(3,478 Views)
what about PDA Module???
(3,333 Views)
Dear Fingger,
You can use LabVIEW with PDA. Please click here for the tutorial.
Fawad
Fawad Nisar
(3,326 Views)
