Can not select Scan Mode
When I start a new project and select target devices, labview will always automatically select FPGA mode. According to the instruction, there should be a step to select the SCAN mode or FPGA mode. Why it does not appear in my system? Thanks
I used NI cRIO-9014 with cRIO-9101 chasiss. The software is NI-compactRIO 15.0.
Thanks a lot for the help.
(3,336 Views)
Accepted by pdslabfranky
What do you mean by "I used NI cRIO-9014 with cRIO-9101 chassis" ? How is your hardware setup ?
From what I read, I think you cannot use Scan Mode with cRIO 9101 but only with module inside the 9101 : http://zone.ni.com/reference/en-XX/help/373197G-01/target6devicehelp/supported_hardware_rt/
CLAMaxime -- Kudos are a great way to say thank you
(3,306 Views)
Thanks! You are correct. Chassis 9101 does not support Scan mode. But It seems like Hybrid mode is ok.
Thanks for the help!
(3,302 Views)
