Can someone tell me what icon is this?
I need help identifying this icon, it's supposedly an spectrogram but i can't find it. If it helps I'm on Labview 2017 SP1.
(1,903 Views)
I don't recognise that as a VI which is part of the base LabVIEW install. I suspect that it is part of a third party library which has been downloaded on your machine.
  • If you press Ctrl+H and hover over the VI it will display it's name and a description of what it does (If the developer has written one)
  • If you open the VI and press Ctrl+Shift+E it will show you where it is locating in the project manager
  • If you want more of an idea of what it does you may have to open it and look at the code to work it out for yourself/post it here and someone else might give you an overview
  • If you just want to reuse it you can copy the VI and paste it somewhere else (Or Ctrl+drag)
(1,869 Views)
I've never used ctrl+shift+E before.  Is that the same thing as "View this VI in project"?  Thanks.
Bill
CLD
(Mid-Level minion.)
(1,859 Views)
Hi
(Ctrl+shift+E ) is the same (View >This VI in project 😞  displays the Project Explorer window with the current VI selected.
Best Regards.
(1,850 Views)
Accepted by JCarlosB
It is "TFA Configure Spectrogram Indicator".  It can be found on the Signal Processing, Time Frequency Analysis, Utilities sub-Palette.  I hope you are familiar with Time-Frequency Spectrograms ...
(1,837 Views)
Also not that this is not part of plain LabVIEW, but part of the Advanced Signal Processing Toolkit . Do you have this toolkit?
(1,823 Views)
Thank you so much, you literally saved my grades
(1,809 Views)
