Can't open LabVIEW project 2018
Hello everyone.
I am new to LabVIEW and I have a fairly basic question.
I have loaded sample file and want to open the file in LabVIEW 2018 but cannot open the. LabVIEW 2018 show this massage and I don't know what I should do to solve this problem.
(4,512 Views)
Accepted by therinoy
Well, either you didn't have a Project, or something else (perhaps "data-driven") is wrong.  Why don't you attach your Project (if its in a Folder, compress the Folder and attach the resulting .zip file).
(4,486 Views)
LabVIEW can only "open" LabVIEW code and related files (VI, llb, lvproj, ctl, etc.).
If you are in LabVIEW and use the file menu entries "open ..." or "open project ...", etc, and you browse to some random non-LabVIEW file, the outcome will not be predictable. Even worse, if the file has one of the recognized extensions, but is something else.
So tell us exactly (step-by-step!) what you are doing, what happens, and what you expect to happen instead. Also define what you mean by "sample file".
Of course, to "open" anything else, you can write a LabVIEW program to do so.
(4,477 Views)
