Can't write diiferent commands in the same row ow command line of VII
Hi guys,
I try to write some commands in the command line to instrument and it doesn't work.
F:C?;F:START?;F:STOP?
F:C? means center frequency,
F:START? start quency
and F:STOP? stop frequency
but the result shows only center frequency.
Someone here knows why?
/mctnnn
Message 1 of 11
(3,125 Views)
What instrument you are using?
If you have code, please post it.
And to avoid frustrated smileys, :S put your code in code brackets
F:START?;
Message 2 of 11
(3,117 Views)
Simple question that you probably already checked, but are the responses just being sent as multiple separate responses and you need to (VISA) Read multiple times (one per query)?
GCentral
Message 3 of 11
(3,107 Views)
I try to write and read to and from a spectrum analyzer.
The code is simple:
/mctnnn
Message 4 of 11
(3,101 Views)
F:START?;
The better solution is you can go into your profile settings on ni.com and disable the automatic smileys.
Message 5 of 11
(3,095 Views)
Thank you cbutcher for your reply,
The response from instrument shows only center frequency.
Can explain further what you mean and how to do it with Read mulitple time?
/mctnnn
Message 6 of 11
(3,094 Views)
Something perhaps like the following (with appropriate setup and close VIs before and after):
You can just wire 3 if the input string is a constantYou can just wire 3 if the input string is a constant
GCentral
Message 7 of 11
(3,081 Views)
You need to perform a read for each query you sent.  So perform 3 reads.
GCentral
Message 8 of 11
(3,077 Views)
Thank cbutcher,
your design looks more professional one.
I try and use it.
/mctnnn
Message 9 of 11
(3,070 Views)
@mctnnn wrote:
Thank cbutcher,
I try and use it.
/mctnnn
I mean, I'm flattered, but just remember that adding "professional looking" stuff isn't as good as not adding any stuff. So if you create a VI that uses these 3 commands all the time, and never changes the written string, then just wire a constant 3 instead of doing the string search.
The string search is useful if you might have an arbitrary number of commands concatenated (and you don't have a way of knowing how many from when you concatenated them, which you should). So I don't anticipate it's likely to be necessary unless the "message building" part is separated from the "visa writing" part by a 'module boundary' etc (software engineering, not LabVIEW term), and you don't want to also pass an integer into the Write/Read function as to number of Reads needed.
GCentral
Message 10 of 11
(3,065 Views)
