Cannot change vi back to edit mode.
I saved a vi so that when it was opened it would come up in run mode using "vi properties", "protection", "locked" but when I open the vi it will not let change it back to edit mode (ctrl-m is grayed out).  Any assistance would be appreciated.  THANKYOU!
Alma
Message 1 of 17
(9,962 Views)
Can you change it from the properties dialog?
Can you attach the VI?
Message 2 of 17
(9,960 Views)
No.  It's grayed out there also.
Message 3 of 17
(9,955 Views)
Sorry not sure how to attach the file.  Using LabVIEW 2009 and it has several sub vi's.
Message 4 of 17
(9,948 Views)
Is the file marked read-only in windows?  (Right-click, "Properties" in explorer)
Message 5 of 17
(9,940 Views)
You have to go back to VI Properties and unprotect the VI.
aputman
Message 6 of 17
(9,937 Views)
We don't care about the subVIs. Just attach the one giving you problems. There is a button to attach files below the field where you compose a reply.
Message 7 of 17
(9,927 Views)
Of course it is, Mike!  and in "Tools>>Options Enviorment ---Saving VIs "Treat Read-only vis as locked" is set (Although just these two things as non-default would not grey out CTRL-M--- a prompt would appear)
SO some source code control settings are also in play here
Try "Tools>>Options  Source Control--- General  "Display Source Control Operations dialog box...."
OR inspect LabVIEW.ini for the key "CustomShortcuts=" and delete the ";<Whatever>,Ctrl+m" entery (Someone repurposed the shortcut?)
Message 8 of 17
(9,917 Views)
If the VI is still running....Ctrl-M will be greyed out.
aputman
Message 9 of 17
(9,898 Views)
Is your VI possibly set to Run When Opened?  You can get around that by dropping the vi onto the block diagram of a new empty VI the double-clicking to open it.
Kelly Bersch
Certified LabVIEW Developer
Kudos are always welcome
Message 10 of 17
(9,889 Views)
