Cannot change vi back to edit mode.
@aputman wrote:
If the VI is still running....Ctrl-M will be greyed out.
Or reservedSmiley Wink There I go missing an obvious piece of data and assuming the vi.state property is Idle
Message 11 of 17
(1,969 Views)
- the vi is attached (hope I did it correctly)
- the vi is not running when I open it
- checked the .ini file nothing in there that I can tell
THANKS for the help! I checked with our IT Support and was able to get a backup copy....with a few changes I should be back on track but it would be nice to know what happened. It seem like it is between a run mode configuration and an .exe.  Any other ideas would be appreciated.
THANKS!
Alma
Message 12 of 17
(1,953 Views)
That vi seams to be a support file inside a build.  Likely a source distrubution!
Block diagrams are removed by the source developers specifically to prevent other users from editing the vi.
Short answer: you don't have editable source code.
Message 13 of 17
(1,944 Views)
Hum?  Not sure how that would have happened.  Is there a way to back out of that?
Message 14 of 17
(1,938 Views)
Rebuild the distrubution and redeploy the build without removing the Block Diagrams-  From the original source code.  Of course, then you risk having code on different systems that do different things- That can lead to "unwanted behavior"-  (What an understatement!)
What are you using for source code control?
Spoiler
The rest of this thead may contain subject matter which evolkes graffically horrorifying images:  Developer discretion is advised
 {EDIT} I I could spell or type I probably would still be stuck programming in some text based languageSmiley Very HappySmiley Very Happy
My command of punctuation sucks too!  All posters are welcome to clairify any posts mangled beyond readability  (But, I'm not the only one to suffer from these things) or ask me what the heck I meant.
Message 15 of 17
(1,931 Views)
Spoiler
Spoiler
The response from Jeff is GRAPHICALLY HORRIFYING and EVOKES memories of Spelling 101.  Teacher discretion is advised.  Smiley Very Happy
aputman
Message 16 of 17
(1,923 Views)
Run into this all the time with people trying to get really old code converted.  What Happens When I Save My VI and Remove Diagrams?
Summary:  You can't do a darn thing with the VI except run it with LabVIEW 2009.
Message 17 of 17
(1,898 Views)
