02-21-2014 02:11 PM
@aputman wrote:
If the VI is still running....Ctrl-M will be greyed out.
Or reserved
There I go missing an obvious piece of data and assuming the vi.state property is Idle
02-21-2014 02:48 PM
- the vi is attached (hope I did it correctly)
- the vi is not running when I open it
- checked the .ini file nothing in there that I can tell
THANKS for the help! I checked with our IT Support and was able to get a backup copy....with a few changes I should be back on track but it would be nice to know what happened. It seem like it is between a run mode configuration and an .exe. Any other ideas would be appreciated.
THANKS!
Alma
02-21-2014 03:01 PM
That vi seams to be a support file inside a build. Likely a source distrubution!
Block diagrams are removed by the source developers specifically to prevent other users from editing the vi.
Short answer: you don't have editable source code.
02-21-2014 03:16 PM
Hum? Not sure how that would have happened. Is there a way to back out of that?
02-21-2014 03:38 PM - edited 02-21-2014 03:53 PM
Rebuild the distrubution and redeploy the build without removing the Block Diagrams- From the original source code. Of course, then you risk having code on different systems that do different things- That can lead to "unwanted behavior"- (What an understatement!)
What are you using for source code control?
{EDIT} I I could spell or type I probably would still be stuck programming in some text based language![]()
My command of punctuation sucks too! All posters are welcome to clairify any posts mangled beyond readability (But, I'm not the only one to suffer from these things) or ask me what the heck I meant.
02-21-2014 03:47 PM
SpoilerThe rest of this thead may contain subject matter which evolkes graffically horrorifying images: Developer discretion is advised
02-22-2014 07:11 AM
Run into this all the time with people trying to get really old code converted. What Happens When I Save My VI and Remove Diagrams?
Summary: You can't do a darn thing with the VI except run it with LabVIEW 2009.
