Cannot find VIs asscociated with DAQmx in Labview
I just got a NI instrument USB-6525. It came with two CDs with DAQmx driver, VER 8.7.1. The instrument is working when I tested in MAX using test panel. However, in the labview 8.6, I cannot find VIs to do digital output in order to control the instrument. Is it because that my labview version is not complete or these DAQmx and Labview are not compatible? Thank you.
(3,553 Views)
You need to be careful about the installation order. Be sure to install the software and then install the driver. In your case, LabVIEW 8.6 and then DAQmx.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,547 Views)
Thank you for the tip. But I did follow this installation order. First Labview, then DAQmx
(3,537 Views)
Try to reinstall DAQmx. Can you post a screenshot of your Measurement I/O Palette in you block diagram?
Adnan Zafar
(3,532 Views)
I think that 8.8 was the first version with LabVIEW 8.6 support and that is what came with 8.6 on the device drivers CD. The latest is 8.9 and you can download it.
Message Edited by Dennis Knutson on 05-15-2009 02:29 PM
(3,529 Views)
Oh, it's actually version 8.7.2. I really didn't even think about version compatibility....apologies for that.
NI-DAQ & LabVIEW Version Compatibility (for Windows)
Adnan Zafar
(3,511 Views)
Thanks a lot for the help. I downloaded the DAXmx8.9 and now it's working with my labview 8.6. Everything is fine now!
(3,467 Views)
