03-05-2019 01:13 PM
Hi
I recently upgraded my PC and reinstalled Windows 10 pro.
After the reinstall, LabVIEW Runtime Engine 2018 (64-bit) f2 Patch fails instantly with the below error message.
I have tried running the installer as administrator, with and without anti-virus enabled.
I have also tried LVRTE 2018 (32-bit) f2 Patch.
I tried Creating an Error Log File for a Software Installation as was suggested in this thread, but that does not generate a log file, but still shows the below error
Does anyone have an idea what I can try next?
BR
Palle
Solved! Go to Solution.
03-05-2019 01:22 PM - edited 03-05-2019 01:24 PM
(Trying not to tread between the lines...)
What was the result of the 32 bit trial? Same?
Did you do all the windows updates after installing w10?
03-05-2019 05:04 PM
Does this help?
03-06-2019 11:34 AM
@altenbach: Yes, the same error for all installers
@billko: Worked like a charm 🙂 Thanks (The region setting: English (Denmark) does not work, in case anyone was wondering 😞 )
