Case Statement doesn't switch.
I'm having an odd problem with a case statement.  I'm passing is a Boolean that is false but the case statement never switches over to the 'false' loop.  I have attached a word doc that has the screen shot of this being single stepped through.  The top picture has the case being highlighted with the probe #8 next to it indicating "False".  In the lower screen shot is the very next step that is highlighting the outer 'while loop' but the case statement is still 'True'.  Has anyone seen this before?
Gary Tyrna
(3,300 Views)
Hello ggaryT,
Is the problem that you aren't seeing the case structure switch over? That won't happen unless highlight execution is on at the top of the screen. Or, is the code in the false case not executing?
-Mello
Data Science Automation
CTA, CLA, CLED
SHAZAM!
(3,287 Views)
Accepted by ggaryt
Hi Mello,
Well I see what you are saying and you are correct the problem with it is the case statement works when highlight execution.  But I have a main case statement in the loop that either allows the state machine loops to execute or hides them and that case switches during single stepping to true or false.  So that was the reason I sent the first e-mail since I could see that case change but not the smaller one.  But if that is the fix well I'll run with it and use the execution highlight to see the case statement switch.
Thanks Again.
Gary Tyrna
(3,271 Views)
