Case structure and timeout
Hello everyone. I need a case structure, which is controlled by a boolean button. I need to use my timeout by switching my button to "true", but it fails:
Best regards
Oesen
(4,591 Views)
Accepted by Oesen
In the false you can wire -1, can you explain why you are trying to do like this and what you want to achieve finally?
(4,589 Views)
Hi P@Anand
My PC is serial port communicated with a scale. The program makes auto measurement every "x" seconds, when i define the timeout to a number "x". But i don't want to use auto measuring sometimes, and will measure by self clicking on the measurement button. So therefore i want at boolean ON/OFF to the timeout value.
Best regards
Oesen
(4,585 Views)
But it works now.
Thanks a lot !
Best regards
Oesen
(4,579 Views)
You can use an event case to toggle using the timeout control. Check the attached code
(4,577 Views)
In these situations, I must prefer using the Select function.  Makes things a lot easier to read.
(4,576 Views)
We are on Page Smiley Wink
(4,572 Views)
