Case structure isn't updated after modification of "enum" type
Do you already have add all the cases for that case structure?
Message 11 of 16
(1,713 Views)
Hi Pavel,
are you using an ENUM - or do you use a RING instead?
Message 12 of 16
(1,710 Views)
@Pavel_47 wrote:
In my version it looks like this
I opened your code in my 2015 and the option is there. Make sure you don't have any coercion dots in your code as your State control is passed around. If the case structure thinks you're just wiring a numeric, it won't understand that your enum has different states to add.
Edit: wow, four replies in under a minute. As dkfire suggested, maybe you already have all the cases added since you posted your code.
Cheers
Message 13 of 16
(1,707 Views)
Yes I've all cases are added into case structure.
So this option appears only if some case are missed ?
Message 14 of 16
(1,693 Views)
Accepted by Pavel_47
Yup. You'll also get an error if you have a case that is no longer present in the enum. LabVIEW understands that you may not want to have a case for every option (hence a Default option), but won't let you have more cases than the enum has.
Cheers
Message 15 of 16
(1,687 Views)
Ok, clear.
Message 16 of 16
(1,669 Views)
