Challenge of the Day: No palette!
@James.M wrote:
@Hooovahh wrote:
@BowenM wrote:
Stacked sequence structure doesnt... (in 2014) 🙂
But stacked sequence isn't on the palette in 2014 right?
You can right click a regular seq structure and convert.
Correct.  There was no requirement given that it had to be on the standard palettes! 😛
Message 11 of 22
(1,844 Views)
Here you go!
Global and Local variables result in this. Though, once you link the variable, it goes to the palette of the control/indicator.
Cheers
Message 12 of 22
(1,844 Views)
Well, it is obviously a constant of some sort.  Time to start digging...
GCentral
Message 13 of 22
(1,838 Views)
Build XY Graph and Build Table express VIs don't have it either. In order to get them on the BD, I had to go through the front panel Express palette, so that's probably why. I don't think they exist on the BD palettes.
Okay, back to work
Cheers
Message 14 of 22
(1,826 Views)
Accepted by topic author X.
@X. wrote:
We are talking BD objects, my bad.
I am talking about this behavior:
Not A Refnum Constant
GCentral
Message 15 of 22
(1,812 Views)
Bravo. That is some weird selective behavior.
Cheers
Message 16 of 22
(1,795 Views)
Decorations
Randall Pursley
Message 17 of 22
(1,791 Views)
@rpursley8 wrote:
Decorations
I guess that counts as a correct answer, even though the right-click menu is not identical to that in the picture I posted. But I did not ask for that.
Kudo.
This being said, I am wondering why the not a refnum constant is such an outcast. After all, you can connect it to a bunch of terminals. Maybe that's the reason?
In any case, I find sometimes frustrating to try my luck with right-cliking, only to be offered no option to access the generic palette (in addition to the default one). This example provides just the illustration of this pushed to its extreme.
Message 18 of 22
(1,753 Views)
@James.M wrote:
Here you go!
Sorry, you guys were so fired up that I got lost in the flow of answers.
That's not a bad answer, although I am not quite clear what you would expect to have access to?
Message 19 of 22
(1,745 Views)
Not really.  The Not A Refnum Constant can be used on ANY reference: Queue, File, Notifier, Occurrence, User Event, etc.  So it kind of makes sense to not assume the file palette.
GCentral
Message 20 of 22
(1,743 Views)
