Change Variant type name programatically
I use Variants to communicate between Queue State Machines similar to the Queued Message Handler Template. These Variants have type names which I use to distinguish between different values. I don't know how I can change them programmatically. At the moment I use String constants with static labels. The problem arises if I get the String from a VI, then I can't change the name.
Here a more elaborate example which is more similar to what I am doing.
(3,785 Views)
Type cast into the same type but label the constant you feed into the type terminal (also a quick and dirty trick for named probes which is how I found out about it):
Spoiler
Redhawk
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
(3,774 Views)
Accepted by Steffen_Zienert
Using Coerce to Type is safer, as you know it's not going to reinterpret the memory.
(3,739 Views)
One day I'll get to move on from 2017 😭
Redhawk
(3,708 Views)
"Coerce to Type" is available in 2017 (and earlier). It's just not visible in the palette: https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Officially-Support-quot-Coerce-to-Type-quot/idi-p/121...
Certified LabVIEW Developer
(3,668 Views)
