Changes in vi won't save ,how come?
Dear all,
I use the "path" to define the  file location. However, when I can changed the value for that "path", I saved it. The program told me it is saved.
However, next time, when I open the VI, it is still the old value. What's wrong there?
Thanks.
(4,633 Views)
duplicate post
Be a little more patient in waiting for an answer
(4,627 Views)
Sorry. I found the title in the early posting was not good so I posted it again.
I want to deleted the old one, but could not find the delete function here.
(4,624 Views)
File>>Save does not save the values in your front-panel controls.  If you want a value to be saved as a default input on a control you need to set it as the default value.  Try right-clicking on the control and going to Data Operations>>Make Current Value Default after you have the path set correctly.  Then do a File>>Save.
Cheers!
-Hook 'Em
(4,617 Views)
Accepted by RoyOfAgent
thanks. I got it.
(4,582 Views)
