Chart configuration
I'm basically trying to see two different signals (one is converted from single scalar to dynamic) in a chart.
I want to see the chart (x axis) only for 200 sec, I'm  formatting the x axis not be auto scaled and choose 0 to 200, however when I click on run, the values on the x axis automatically change (its not 0 to 100 anymore).
I have attached an example, all I want to see is the continuous sine wave with the value of the switch (0 or 1).
Will appreciate any help.
(3,734 Views)
If you probe the dynamic data, you will notice that your timestamps are not aligned.
Attached is a possible fix.
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(3,717 Views)
Possible Solution:
1.) Change your time to Absolute Time as below:
2.) Format your x-axis to display absolute time as below. Right click on the x-axis and go to Properties to get this window.
3.) Set your chart history length to 400 data points because you collecting at 2 Hz and want to keep 200 seconds of data. Right click on the graph and go to Chart History Length to do this.
(3,695 Views)
Simple procedure, I completely forgot about the time stamps.
Thank you
(3,686 Views)
Accepted by D_Raz
Remember to mark a post as a solution so that others can benefit from your question.
-CC
"If anyone needs me, I'll be in the Angry Dome!"
(3,682 Views)
