Checksum
Since you are using third party hardware, the commands will most likely be device specific.  You can test the serial connection itself by performing a loopback test.  This simply verifies that your serial connection and cable are working.
In terms of communicating with the device itself, you will need to consult the user manual or contact the device manufacturer.  The commands should be fairly similar to those of the Digital MFC Interface, so the instructions for that should be fairly useful.
Lauren L
Applications Engineering
Message 11 of 18
(3,306 Views)
ali26
I used  Labview version 8.2, and the MFC 8100 series unit of celerity. I also used the RS485 serial communication. and the issue was that I anly have the instructions of the RS485 communication Protocol of Digital MFC Interface.
thank you for you response "merci pour votre aide"
Message 12 of 18
(3,294 Views)
laurant L,
what about the checksum, is this instruction will sent to the MFC as the other instructions?
think you
ali26
Message 13 of 18
(3,291 Views)
I 'm a beguner at labview, and I need help , because I want to commande the MFC and only what I have is the instructions. and I don't know the way and the forme that this instructions is sent to the instrument " MFC 1800 series celerity, communication RS485, and labview8.2".
think you for help
Message 14 of 18
(3,271 Views)
In terms of getting started with serial communication, I recommend taking a look at our Developer Zone tutorial on Instrument Control in LabVIEW.  It provides a good step by step guide on getting started, determining what types of commands to send, and communicating with instruments.  There are also a number of good related links at the bottom of the document that may be worth checking out.
On the subject of the checksum, I am not entirely sure what you are asking.  The checksum is usually transmitted with data to assist in error detection, but the instruction itself would be device specific.  If you can clarify your question, maybe I can be of more assistance.
Lauren L
Message 15 of 18
(3,248 Views)
bonjour ts le monde,
voila je veux commander le mass flow controller/meter 1800series  sous labview.  j'utilise la communication serie RS485, avec   VISA  je veux envoyer  des instructions (format Hexa), mais le prolème c'est que les instructions que j'envoie je les reçoi sur le buffer à lire.
Message 16 of 18
(3,214 Views)
Bonjour gotgot,
S.V.P.  Utiliser le forum francophone pour les questions en français.
En ce qui a trait à votre problème, de qu'elle "buffer à lire" parler vous.  Si vous faite un "loop back test", vous aller recevoir les instructions sur le même port et donc sur votre buffer à lire.  Si vous connecter votre intrument, le buffer à lire de votre instrument reçoit les instructions.  Êtes-vous en train de faire un loop back test?  Sinon, comment avez vous connecté votre système?  Est-ce que vous avez tester votre instrument dans Measurement and Automation Explorer?
O. Proulx
www.ni.com/support
Message 17 of 18
(3,189 Views)
Did you guys figure out the MFC com. thingy.  Let me know if you need any more information.
Tim
MFChelp.com
Message 18 of 18
(2,895 Views)
