Chromatography analysis .vi
Hello Batiston,
Were you able to pass through the limitations you mention for the VI's on Chromatography?
We can provide assistance to help you consolidate the analysis with the zoom feature.
Also, did you got approval from your colleague for sharing this code?
David
Message 11 of 12
(621 Views)
Hello David
Thanks for asking me again
1) Imagining a chromatographic peak. Thus, I would like to integrate this peak. Then I would like to obtain the area this peak, by LabView.
2) Imagining two chromatographic peaks: the first peak is smaller and the second peak is huge. Then the enormous intensity signal of the second peak does the first peak to be tiny. This way, I would like a tool to get a zoom of the first peak.
Now, I can send to you the code. Could be by here or Dropbox? Do you have another idea to share the code?
Message 12 of 12
(592 Views)
