Class Properties Dialog Box - Wire Pict Ring - Location?
Is the array limited to 8X8?
I know I (successfully) changed a class wire width to 100 years ago. Not sure if it still works, or if it should.
Message 11 of 13
(615 Views)
I think the pattern arrays are limited to 8x8, but that doesn't limit the wire width.  The pattern repeats when you go beyond a wire width of 8.
Message 12 of 13
(607 Views)
Message 13 of 13
(593 Views)
