Clear Waveform Graph - No History Property node
How do you clear the waveform graph since there is no history property node available for that waveform type that I can see to set. The waveform chart has one, but not the graph. Not sure why it doesn't have the history node, but I'm sure there is a way to clear it. Any ideas?
(5,522 Views)
Accepted by QRP
Use the waveforms graphs's value property node. Wire an empty array to it.
Hey presto, graph clears...
(5,517 Views)
If you don't want to do it programatically then right click on graph go to data operations and then clear graph etc.
Naqqash
(5,516 Views)
Thanks Guys. That worked... I'm not sure why the developer wounldn't just keep the clearing process the same between the different waveform types since that just adds confusion in my opinion. What's wrong with a history node for both types?
Oh well, moving forward thanks again...
(5,512 Views)
