Closing Serial Port on Stop/Abort
Whenever my program is stopped using the abort button labview gives it does not get a chance to close the serial port, thus making other programs not able to use the serial port. Is there a way I can execute some code when stopping my program aside from making my own stop button?
Cason Clagg
SwRI
LabView 7.1, Windows XP
Message 1 of 16
(4,590 Views)
The abort button is not meant to be used as anything other than a debug tool. The correct way to stop you program is to have a stop button or use the event structure to capture the application exit event. I would recomend that for the user, the toolbar not be visible at all.
Message 2 of 16
(4,583 Views)
Dennis is spot on. Hide the entire tool bar from the user. The abort is a hard exit - your ports and all of your controls don't have a chance against it. Attached is a jpeg, showing a common method I use to close the ports, and do some general "housekeeping" on Exit. (I assume you are using VISA).
Message Edited by Broken Arrow on 06-27-2005 09:41 AM
Richard
Message 3 of 16
(4,577 Views)
I was unaware that a housekeeping case could be made like that. Seems like there would be a way to do things on exit easily, and there it is. Thanks for the post!
Cason Clagg
SwRI
Message 4 of 16
(4,571 Views)
It's actually easier with the event structure. If you have a stop button, in the value change event for the button, you just have to put your cleanup code. It does not have to be outside the main while loop.
Message 5 of 16
(4,565 Views)
You say tomato
Richard
Message 6 of 16
(4,556 Views)
You say tomato
If you've never heard that song, it doesn't make sense when you read it. 😉
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
Message 7 of 16
(4,548 Views)
Potato.
___________________
Try to take over the world!
Message 8 of 16
(4,536 Views)
Tangent.
Cason Clagg
SwRI
Message 9 of 16
(4,530 Views)
hehe, sorry, couldn't resist.
I was ststioned in Japan for a couple years and heard that song in a Karaoke bar being sung by a couple of the local folks and they were pronouncing the "tomato" and "potato" the same. It was good for a laugh at the time.
Ed
Message 10 of 16
(4,522 Views)
