Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Cluster into array of bit
gantry
Member
11-20-2002
03:33 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Hi
Well, my title is my question. Is it possible
to transform a cluster to an array of bit ? I am
on LabView 5.1.
Thanks in advance
0
Kudos
Message
1
of 2
(2,943 Views)
Reply
Re: Cluster into array of bit
Al_S
Active Participant
11-20-2002
08:23 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Sure. In LabView 6.1 there's a Cluster to Array function in the Array or Cluster palette. If that's not available in 5.1 you can use the Unbundle function (in the Cluster palette) then the Build Array function (in the array palette).
0
Kudos
Message
2
of 2
(2,943 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
