Color menu generated from serial strings
Hello all, I opened a serial connection to a comexpress module that was in the bios using Putty.  The Putty window shows a color menu that looks almost the same as the one on an HDMI monitor.  When I read the data using serial read VI's I get stuff that looks like this:
   System Date07/   System Date2015/]                  System Time           03[   System Time27:   System Time46:]                    System Date07/   System Date2015/]                  System Time           03[   System Time27:   System Time47:]                    System Date07/   System Date2015/]                  System Time           03[   System Time27:   System Time48:]
I can't find anything saying how to interprete this stuff so I could try and display it the same way.  Anyone know what this is and/or what the syntax is?
(3,447 Views)
Hi Hepcat,
read Wikipedia on ANSI escape codes
(3,444 Views)
