 medum
			medum
			05-25-2024 05:48 AM
Hello guys,
I have an 1D-Array. And want to compare that with other 1D Array of minimum distance and maximum distance. The problem is the one Array have not a constant step size. In one step he have +10 and the other +11 and then again +10 ...
I want to calculate from two arrays the minimal and maximal difference.
Is there any example in LabVIEW?
Solved! Go to Solution.
 ZYOng
			ZYOng
			05-25-2024 09:50 AM
It will be more informative if you post your code and show how the data is being generated.
 altenbach
			altenbach
			05-26-2024 01:29 PM
Is this related to any of you other similar threads? Maybe it would be easier to keep it all in one place.
What problem are you actually trying to solve?
06-02-2024 03:59 AM
I mean one array has a stepszize from 10 and the other has changing stepsize +10 +11 +10+11
 altenbach
			altenbach
			06-03-2024 01:37 PM - edited 06-03-2024 01:41 PM
You are not making any sense. A 1D DBL array only has index/value pairs. There is no variable steps size unless this is a 1D complex array where e.g. RE is the X value or if this is an 1D array of xy point clusters.
You need to be significantly more specific!
If they data is x/y, you can compare the y values by e.g. interpolating, bringing both arrays to a common x ramp.
06-03-2024 03:13 PM
how is that look likes in LabVIEW
 altenbach
			altenbach
			06-03-2024 03:55 PM
06-04-2024 12:55 AM
sorry.
First if I have an an array with constant step size.
The other has differenz step size changing + 10, 11+ 10 and so an
For example:
x = 1,11,21,31,41,51,61,71,81,91,101
y = 1,11,22, 32, 43, 53, 64, 74, …
What do u see? Because of the changing step size in y the difference between the values are growing.
I thought first of all that are const the difference. Iwould use the mean (10+11)/2 and then check with range and coerce that my values into the range.
But i think that is not working. Idk what can I do 😕
 Yamaeda
			Yamaeda
			06-04-2024 06:14 AM
If the step sizes are correct you can simply upscale each array with the step size and you'll get 1 value/1 step. If the step size is dynamic it's messier, but the same logic applies.
If array 1 is:
(1,0),(11,2),(21,3) and you upscale with a factor 10 you should get a value for 1,2,3,4...
If array 2 is:
(1,0),(12,2),(23,3) and you upscale with a factor 11 you should get a value for 1,2,3,4...
06-04-2024 09:13 AM
How it is look like in LabVIEW?
Do u have an example?
