Compare two string 2D arrays
I would like to get the indexes of the different elements between two string arrays. I can do it element by element but it seems stupid. Perhaps there is a simpler way that can do the job? Does anyone have ideas?
Thanks in advance.
Best Regards,
K
(4,514 Views)
Go row by row and compare the 1-D arrays.  If they are different then look for the Falses in that 1-D array.
(4,493 Views)
Accepted by KwanSHL
try this:
(Hint: Conditional and concatenating output tunnels…)
(4,471 Views)
Thanks guys, this will do the trick!
(4,465 Views)
(The above assumes that the two arrays are identical in size and that equal entries need to be binary identical. Depending on where these strings come from, you might want to do a case insensitive match and/or ignore leading and trailing whitespace if present.)
(4,457 Views)
