Comparing multiple elements within a 2D array
Hi, I have a doubt that how can we compare each element in 2D array with the other elements in the same array. I tried some methods. But those didn't work. I have attached an image of the 2D array. I just want to know the logic.
Best Regards,
Dhans 😉
Kudos are welcome 😉
Aspirant Labview Programmer (Labview 14) 😉
Message 1 of 8
(6,358 Views)
Compare how?  That they are different?  They are outside of a given range?
Message 2 of 8
(6,353 Views)
Hi, Sorry to say that. Here I need a comparison of elements with the same values. If any one of the elements in the 2D array has same value or equal to the other elements in the same array I need to save that status as boolean array.
Best Regards,
Dhans 😉
Kudos are welcome 😉
Message 3 of 8
(6,339 Views)
Accepted by dhans
I am not sure I understand your requirement fully as yet. Try this one:
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 4 of 8
(6,285 Views)
Thanks for the reply. Can you attach the output and False 'case' of the case structure snippets?
Best Regards,
Dhans 😉
Kudos are welcome 😉
Message 5 of 8
(6,260 Views)
Yes. This is the one I was seeking for. But I have one more doubt. In the attached image I have marked an area. In what situation logic inside that area is useful? With out that 'greater than' logic, I can get an output required. So whats the reason behind that comparison logic?
Best Regards,
Dhans 😉
Kudos are welcome 😉
Message 6 of 8
(6,251 Views)
The Less Than is not really needed.  You can use a TRUE constant.  But the second Replace Array Subset is needed due to set the current element TRUE.  The first one sets the match's element to TRUE.
Message 7 of 8
(6,218 Views)
Hi Crossrulz,
Thanks.
Best Regards,
Dhans 😉
Kudos are welcome 😉
Message 8 of 8
(6,202 Views)
