Component Level IP: Generate and Check Syntax Error
Update - added MinGW G++ as well, re-copied, re-tried and got the same error 1097.  I'm wondering if there's a specific older version of MinGW that works, while the current one does not.
Message 11 of 12
(1,142 Views)
For the record, I was able to reproduce the results using the following file, selected because the release schedule was the last release on sourceforge prior to the earlier messages in this thread.
i686-7.3.0-release-win32-sjlj-rt_v5-rev0.7z
It was located, at the time, here:  https://sourceforge.net/projects/mingw-w64/files/Toolchains%20targetting%20Win32/Personal%20Builds/m...
Steps to reproduce the successful workaround:
  1. Download file i686-7.3.0-release-win32-sjlj-rt_v5-rev0.7z
  2. Extract folder, and navigate to the root folder "mingw32" within that archive
  3. Navigate to C:\NIFPGA\programs\Vivado2015_4\tps\mingw, and make a backup of the 5.0.0 folder
  4. Navigate into C:\NIFPGA\programs\Vivado2015_4\tps\mingw\5.0.0\win32.o\nt
  5. Copy the entire contents of the extracted 7.3.0 release in Step 2 into the folder described in step 4.
  6. Choose YES when asked to overwrite existing files
Starting up labview enabled me to pass the CLIP syntax check without any issues.
Thanks to everyone earlier who posted.  I hope this set of links and specific versions will help others in the future.
-J
Message 12 of 12
(1,125 Views)
