Compound Arithmetic different array size
Hi all,
I have two array with different size,
 Array 1         Array 2
      1                0
      1                0
      1                0
      1
 If compound arithmetic OR was performed on them, I got output
1
1
1
Is there any way I can get
1
1
1
1
Thank you.
Message Edited by oly on 01-19-2010 02:15 PM
(3,991 Views)
This is normal behavior. To have 1 1 1 1 you will have to compare the array sizes and append the good amount of 0 to the smallest array and then OR them.
Ben
(3,967 Views)
You could initilize the shortest arry to the same size as the longest. The default value would be zero for the cells that do not get written in.
Tim
GHSP
(3,962 Views)
Thank you for the ideas!
Array 2  is the output of some program, its size varies from 0 to hundred...
array 1 size is also variable, from 0 to 5...
so I am thinking somehow can I pad 0s after the smaller size array to make the sizes of them equal?
(3,942 Views)
something like this? if your array size changes all the time from each time the code is called. You could also use a case structure instead of 3 selectors
(3,935 Views)
Accepted by oly
Padding is most easily done using "reshape array". Here's some minimal code that pads the shorter array to the size of the longer one of the two.
Message Edited by altenbach on 01-19-2010 03:52 PM
(3,924 Views)
