Computer requirements as LV RT Target.
I am developing a Machine Vision application in which a computer needs to use as RT Target.
I would like to clarify some issues in order to choose the proper hardware components.
1. Does LV RT supports Intel Core 2 Quad family of processors? I think so.
2. I am pondering two hardware architectures:
 A. ATX motherboard.
 B. Single Board computer in a Backplane.
   Are both posible?
3. At least a PCIe card (NI PCIe-8255R IEEE 1394 Interfaces with Reconfigurable DIO) needs to
   be used. Does it makes any difference wether is it plugged in an ATX motherboard(A) or in
   a passive blackplane (B)?
4. Is the HARD DISK a must? Could a Compact Flash + IDE adapter be used instead?.
Any help with any of these questions is welcome.
(2,943 Views)
Hi Eblanco,
This is a manual about How to create a RT Desktop target from a PC,http://www.ni.com/pdf/manuals/371857a.pdf . Also, this should help you.http://zone.ni.com/devzone/cda/tut/p/id/8239?OpenDocument
Message Edited by mallyaprs on 04-30-2009 11:16 PM
-Mallya
" Appreciate and motivate those who help"
(2,930 Views)
Despite the documentation by NI, I am still searching for answers to my specific case.
I would appreciate any comment or suggestion by anyone who had faced any hardware issue similar to this.
Thanks in advance for your help.
(2,890 Views)
