Conect LabVIEW to Raspberry Pi 4
I have a problem. I am triying to program Raspberry Pi 4 with LabVIEW, but the device isn't recongnized... I did the necessary configuration....
(2,095 Views)
We need a lot more information to help you out such as,
  • What is running on RPi 4 that is going to connect with LabVIEW?
  • Where is LabVIEW running - some other windows laptop?
  • What documentation are you following to set these things up?
  • What is your goal? why do you need to get Rpi work with LabVIEW?
  • What version of LabVIEW and what toolkits?
  • What steps have you taken to debug this and how did you set the current non-working setup?
Santhosh
Soliton Technologies
(2,079 Views)
 I want to program RPi 4 with LabVIEW for IoT applications ...The version of LabVIEW is 2019 and I occupy the Markhup toolkit...
(2,066 Views)
Hi Cel19,
I think you have the answer in your first picture - "You will only be able to connect to and use the device from LabVIEW 2014".
NI refurbished the LINX toolkit in LabVIEW 2020 Community Edition (which is free), so try out that one.
Also, all the discussion about the LINX toolkit have own thread on the forum, check here:
HOBBYIST TOOLKIT
Hope this helps,
_______________________________________________________________
-Patrik
CLA || CTA
If it helps - Kudo it, if it answers - Mark As Solution
(2,053 Views)
